It is currently Sat Nov 07, 2026 1:10 am
 Post subject: 60" e-banana
PostPosted: Wed May 30, 2007 5:46 pm
請問各位師兄師傅:
60" e-banana 應如何配搭?
我打算用 7 cell 電, 請比D意見.
Stanley, 你以前個隻又點配搭架?
PostPosted: Wed May 30, 2007 6:45 pm
點配搭都無咪問題,但最緊要係D防水裝置造得好D!
錫紙、膠袋一定要包到實個接收和電變。
隻電蕉好鬼易扭計,行慢少少就會反肚,你一定要睇實佢!反肚之後就好麻煩,會左反右反,好難救!
我以前既配搭
$400 無碳刷摩打,Hecker和大陸募牌都試過,無大分別
比賽時就用1200mah 兩cell,平時玩就用1800三cell
槳就用13x7 Aeronut floding prop 再拖4:1 gear
PostPosted: Wed May 30, 2007 9:21 pm
:P :P Hey Stanley,
Personally, using a 13x7 is a bit too extreme for a 60" plane. That's may be why the plane always out of control!!
I would suggest a 12x8 or 11x9 instead.
BR,
Pong Pong :roll: :roll:
PostPosted: Fri Jun 01, 2007 1:24 pm
點解要用減速齒?可否用400摩打直出?
PostPosted: Fri Jun 01, 2007 6:45 pm
:shock:
Donny wrote:
點解要用減速齒?
Just like driving your car. You cannot drive up to FNS all the way in gear 5, and likewise, using gear 1 on highway. We have to use an appropriate gear ratio.
Pong Pong :P :P
PostPosted: Fri Jun 01, 2007 7:01 pm
That means it is not powerful enough for a 60"
sail plane if I don't use gears?
PostPosted: Fri Jun 01, 2007 7:15 pm
Donny,
No exactly. It depends on what you want. Speed or thurst?
:idea: :idea:
