It is currently Sat Nov 07, 2026 9:48 am
PostPosted: Sat Sep 11, 2010 8:58 pm
I have import the new wing servo MKS DS 6125 wing servo , it is a extremely high power and fast speed servo . detail spec here .size 30x10x35.5 mm weight 28.8g 0.15sec(4.8v)/0.12sec(6.0v) 6.6kg/cm (4.8v) 8.2 kg/cm(6.0v) two bearing and Cr-Ti alloy gear and all aluminun case .Smartmodel will included special third bearing mounting plate .it make the servo install easy and gear more long life and centre point more accute !
