It is currently Sat Jun 20, 2026 9:56 am
 Post subject: Beijing contest August
PostPosted: Fri May 04, 2012 1:04 am
The Beijing annual DLG contest is open for registration now,
I have copied the below info from tsmx:
初步定于8月25日和26日在北京风之翼俱乐部场地举办第6届北京风之翼DLG大赛,这是比赛的预告,如果你对参加真正的DLG比赛有兴趣并渴望尝试多种不同的比赛科目;如果你希望与国内的高手同场较量,一决高下;如果你想在赛场上欣赏各种性能优异的DLG模型并寻找新设计的灵感;那就请加入我们,我们会随后公布详细的赛程安排。
把这个日期标记到你的日程上, 报名请跟贴!
比赛时间:2012年月25、26日
比赛地点:北京风之翼俱乐部大草地 (查看大图)
注册费用:人民币XXX元 (待定,用于赛事组织,饮水,午餐,奖杯)
赛程安排:预赛每组8人,飞6轮,取5个较好成绩计算预赛名次,预赛前8名进入决赛。决赛飞4轮,并以4轮的成绩总和计算最终名次。前8名颁发奖状。
预赛科目:
1. 任务 D - 15s 递增
10分钟比赛时间,顺序飞以下时间 - 0:30, 0:45, 0:60, 1:15, 1:30, 1:45, 2:00
2. 任务 B - 最后2组*4:00
10分钟比赛时间,记最后两次成绩,最长成绩计时4:00
3. 任务 H - 1:00, 2:00, 3:00, 4:00
10分钟比赛时间,按任意顺序飞出以下成绩1:00, 2:00, 3:00, 4:00
4. 任务 A - 最长 5:00
7分钟比赛时间,记最后1次成绩,最长成绩计时5:00
5. 任务 C - 一齐起飞3个3:00
一齐起飞,飞3次, 最长计时3分钟
6. 任务 G - 最好的5个2:00
10分钟比赛时间, 取最好的5次成绩,最长成绩计时2:00
决赛科目:
1. 任务 B - 最后2组*4:00
2. 任务 C - 一齐起飞3个3:00
一齐起飞,飞3次, 最长计时3分钟
3. 任务 J - 最后的3组3:00
10分钟比赛时间,记最后三次成绩,最长成绩计时3:00
4. 任务 H - 1:00, 2:00, 3:00, 4:00
http://www.tsmx.cn/bbs/viewthread.php?t ... 3D1&page=1
PostPosted: Sat Aug 25, 2012 10:01 pm
Well done Thomas :o
Congratulations to your outstanding achievement in this contest :o
PostPosted: Mon Aug 27, 2012 10:57 am
Well done Thomas!
YOU ARE NEEDED IN OUR COMMUNITY!
PostPosted: Mon Aug 27, 2012 2:22 pm
Thank you guys!
Also, big thank you to the organizing club Wind Wings Club and Ma Yong. Thanks Thomas Wang for picking me up at the airport! And thank you Gao Laoshi for doing the scores.
Arrived Friday noon and checked in to my hotel across from the field. After arriving at the field we went to grab a late lunch before going back to the field to practice.
When we got back to the field it was slightly windy, perfect for my planes, and proceeded to trim them and observe the field conditions. My caller Tang Zhigao arrived later, and we practiced some all-up-last-downs in the calm evening air. It was very lucky that we practiced in those conditions Friday evening and trimmed our planes to those conditions too, the whole prelim contest the next day was very calm.
Prelim conditions were dead calm with very little wind and very little thermal activity. The main requirement was to work light lift (which was good for my 250g plane) and to launch high. Thomas Wang and Pangzi were both very consistent with very high launches and made good times. I was in trouble during the 4th prelim round and only got a 639, luckily I was able to drop that. Throughout the prelims I found myself not able to get any reliable thermal reads because of how still the air was (perhaps the thermals simply weren't there!). There were a couple high large thermals during the prelims, but for the most part it was very weak and more often than not I was simply not coming down as fast when I circled.
Prelim scores for the top 8:
Thomas Wang: 4000
Pangzi: 4000
Thomas Lee: 3882
Youlan: 3752
Mr. Wang: 3747
Mr. Xu: 3636
Kelly Cai: 3587
Adnan: 3418
After lunch the flyoffs started, and by then the wind has started to pick up, and stayed somewhat windy for the entire 4 rounds. It was a favourable change in conditions for me, and I was able to fly the entire 4 rounds with my 250gram Neos without any ballast as well.
First round was Task B, 10 minute window, last 2 flights count, 4 minutes max.
My first flight was 3:5X if I remember correctly, dropping a few seconds. I had a good read and flew straight to it off launch and climbed well, but dropped out of the thermal early and came down too fast in the sink. I do not remember what my 2nd flight time was, but I believe it was lower. Had a great read before launch as well, and flew right to the thermal, but dropped out of the edge. This is something I need to work on. While making my way back I encountered a few patches of light air and circled a bit to slow the descent, before coming back to the field. While coming back I had a midair with another plane which spent us spinning, and I was dangerously close to the ground before I recovered the plane. It was very nerve-wracking, I saw Thomas Wang's Stobel V3 coming in behind and above me, but proceeded to land out, I knew it would be 50/50 on getting back myself being lower than the Stobel. Managed to squeeze the last bit of ground effect out of the plane and crossed the boundary with maybe a foot to spare at best, phew!!!!! Upon inspection there was no damage to my plane.
2nd round was Task C, All up last down, 3 minutes max.
This round was fairly uneventful, had good reads throughout the round and flew ok. 2nd flight was not the best and left a bit on the table.
3rd round was Task J, 10 minute window, last 3 flights count, 3 minutes max.
Again, not a very eventful round, wind was picking up and I still had good reads on the air. I ended up putting a lot of hurt on the others in this round, I think the 2nd highest score in this round was 780. If I remember correctly after this 3rd round I was leading the flyoffs by a couple hundred points out of the max of 3000 (think I was around 29XX).
4th round was Task H, 10 minute window, 1-2-3-4 minute maxes.
I knew before the round that I was leading by a fair bit, and all I had to do was fly consistently and should be able to keep my top place. Got very good reads downwind every flight and got the 1, 3, and 4 minute flights. I did screw up though, and dropped my 2 minute flight with a landout, was indecisive in the air whether to turn around and come back, or to fly to the left a bit more to look for a low level patch of air, and those few seconds in sink left me with very very little height and I missed the boundary by a good 10+ meters.
I have not seen the final score sheet yet, and only the top 3 scores were announced (the rest of the flyoff was only announced with standings), so I do not remember the exact scores:
1. Thomas Lee (Hong Kong): 3912
2. Kelly Cai (Shanghai): 3496
3. Adnan (Singapore): 3270
4. Mr. Xu (Beijing) 3119
5. Thomas Wang (Beijing) 2943
6. Pangzi (Beijing) 2816
7. Youlan (Ningbo)2665
8. Denver (Beijing) 2389
Random thoughts: I need a much higher launch to gain an advantage during the calm air conditions. Windy in Beijing is calm in Shenzhen. Need higher launc height. Thermals are much stronger in Beijing as well. Need higher launch height. Beijing is very dusty but the weather feels GREAT. Flying shoeless feels so good. Need to continue to further improve my air reading skills. Improve launch height. Be more decisive. And launch higher.
I hope we can send a couple more pilots to Beijing next year from Hong Kong (and South China). Airfare, hotel, food, and entry fee together is about 3000 HKD, not a bad way to spend a weekend with friends :)
Thomas
Aug 27, 2012
PostPosted: Mon Aug 27, 2012 2:35 pm
PostPosted: Mon Aug 27, 2012 3:09 pm
Well done Thomas! Congratulation on your win.
Your insightful description of this event is very simulating, I hope we can have more local DLG activities to get the ball running. Perhaps, some field trips across the border to shenzhen during weekends would be interesting. Cheers!
PostPosted: Tue Aug 28, 2012 10:01 am
Thanks Stanley!
Hopefully there is some interest to do another Sham Chung visit in September, or perhaps a trip to Shenzhen in September!
The field we are flying now is very easily accessible, there is a MTR station on the field itself. If some people are interested, I will try to coordinate with the other Southern China DLG pilots and try to get them to go to Shenzhen on the same day to fly together, that should provide a very fun atmosphere for everyone!
Thomas
