It is currently Fri Nov 06, 2026 10:56 pm
PostPosted: Fri Sep 06, 2013 10:19 am
出讓 M M Glider Tech MiG 15 EPP Slop Glider
The MiG 15 was made to fit standard size radio gear, two or four channels.
The MiG 15 can handle just about anything you can throw at it. Its all EPP construction allows for 'full-tilt' bungee launches as well as heavy duty combat 'crunches'. The MiG 15 is very competitive with all the existing combat planes available today.
Specifications
Wing Span : 48 in.
Wing Area : 480 sq. in.
Typical Flying Weight : 20 - 25 oz.
Airfoil : SD6060
Construction : Expanded Polypropylene (EPP) Foam
Manual, Label...
100% New in box
Please check http://www.mmglidertech.com/ for more information.
原價US$69.95(Plus Shipping) 現HK$700.00
