| Flight Simulator for F3F http://rcsail.com/forum/viewtopic.php?f=8&t=114 |
Page 1 of 2 |
| Author: | K.Y.Mak [ Sat May 08, 2004 3:14 pm ] |
| Post subject: | Flight Simulator for F3F |
After some searching on internet, I found a flight simulator that was said to support F3F simulation. There's a forum on the topic in Yahoo. Have a look at the following link. http://groups.yahoo.com/group/crrcsim/ I've not check out on the software yet, but it seems to be what we are looking for! |
| Author: | K.Y.Mak [ Sat May 08, 2004 8:43 pm ] |
我由呢個法國網站 download 左個 CRRCSIM F3F 版泥試。 又真係 Work http://obor.free.fr/navigator.php?url=/ ... =Logiciels 不過我部電腦行起上泥好慢,只好將 display set 到好平板,吟飛行就飛得快好多。個場好似德國個 Viking 賽場吟。 幾好
可惜我只可以用 Joystick 泥玩,好難控掣! 要想方法整個 RC控既連接線至得! 試啦! 都幾好 |
| Author: | Stanley [ Sat May 08, 2004 9:56 pm ] |
亞麥我都玩過呢個Simulator,但我連Joystick都無,只喺用個mouse玩過。曾經嘗試整條Interface cable,買咗啲Processor chip 和其他料,又download咗佢哋個program,但最後借唔到個Programmer去燒個Program落粒chip度,買個Programmer就很貴,所以一直放低無跟進。而家我唸最好又方便嘅方法就是用個PPM to USB 嘅 converter,可以support任何PC window XP。但這樣的converter暫時只有英國一間公司有做,價錢要幾十鎊,好貴。早前聽Ringo講佢會做個PPM to USB interface cable,會價錢合理,唔知幾時先搞得掂? |
| Author: | K.Y.Mak [ Sat May 08, 2004 10:43 pm ] |
[quote="Stanley"]買咗啲Processor chip 和其他料,又download咗佢哋個program,但最後借唔到個Programmer去燒個Program落粒chip度,quote] Stanley, 我係個 crrcsim 既Files區見到個 audio-interface 既資料。 http://groups.yahoo.com/group/crrcsim/f ... ce/images/
佢睇泥只係一條直接由個控連接到部電腦既 stereo mini-jack 。利用音波傳送指令。 定係有 D 野我睇溜左呀? |
| Author: | Stanley [ Sat May 08, 2004 11:35 pm ] |
我聽人講過用Audio input都得,但就小心調較個audio level (line in)。我亦計過如果用audio input 再set咗個 audio 嘅 A/D converter 嘅 sampling frequency 喺44.1kHZ (common CD quality audio),用每一個 PPM 嘅 frame 喺20ms 和10 條 channels 計,每條Channel 只有 88 個 samples 左右,即喺話每條r/c channel 只可以有 88 個steps 嘅 resolution,比起我們一般用嘅PCM1024 有1024 個steps就少了好多!唔知控制起上嚟會唔會跳下跳下咁。不過呢個方法真喺幾方使,你不防試試,睇吓個 simulator 控得好唔好。 |
| Author: | K.Y.Mak [ Sat May 08, 2004 11:43 pm ] |
Stanley wrote: 我聽人講過用Audio input都得,但就小心調較個audio level (line in)。我亦計過如果用audio input 再set咗個 audio 嘅 A/D converter 嘅 sampling frequency 喺44.1kHZ (common CD quality audio),用每一個 PPM 嘅 frame 喺20ms 和10 條 channels 計,每條Channel 只有 88 個 samples 左右,即喺話每條r/c channel 只可以有 88 個steps 嘅 resolution,比起我們一般用嘅PCM1024 有1024 個steps就少了好多!唔知控制起上嚟會唔會跳下跳下咁。不過呢個方法真喺幾方使,你不防試試,睇吓個 simulator 控得好唔好。
Stanley, 我己經試左啦。 飛起上泥好過用 mouse 或者 joystick 好多 D 控制都唔冇覺得跳跳。 不過個控D音波就係 speaker 聽得到!要想方法將 D 雜音除去 快D整條線試啦,只需連接倆支pin,好方便 |
| Author: | Stanley [ Sun May 09, 2004 12:08 am ] |
咁我就試吓整番條線玩吓。然後操fit啲,遲啲比較吓大家嘅F3F best time 好唔好。最好如果揾到方法set埋隻機個啲 properties 如翼形等等就更加好,到時又可以在PC上飛隻Sting 或者 NYX F3F 就好啦! |
| Author: | K.Y.Mak [ Sun May 09, 2004 12:24 am ] |
This is one of my best rounds at 39.95 sec. This type of site is very difficult to fly! very easy getting blow into the inland!
| Author: | K.Y.Mak [ Thu May 13, 2004 12:27 am ] |
各位師兄, 我玩左幾日 CRRCsim-F3F ,覺得好正。 所以係唔同既地方,將幾個必要既檔案 download 左返泥。集成左個網頁,以方便大家安裝泥玩。 應該一日半日就有得玩。 重有個龍虎榜,等大家可以將你D飛行記錄登上去。 其他人可以 download 呢D 飛行記錄檔案,係自已部電腦重播。 更加可以自已同佢一齊飛,一較高下 我試過同我自已個最快記錄一齊飛,原來咁都會有好大心理壓力。咁樣飛經常會大失水準同撞机落海! 入泥睇睇啦 http://i4kai.rchomepage.com/ |
| Author: | Tsz Ming [ Thu May 13, 2004 2:22 am ] |
Mak Very cool idea!!! But my question is...is it a freeware? Tsz Ming |
| Author: | louie [ Thu May 13, 2004 3:33 pm ] |
| Post subject: | Tx control emulate a joystick thru PC microphone input |
Hi all, Here is a program, called SmartPropo to emulate your Futaba or JR Control into a Joystick, and you need to use a cable connect from your Tx controller into the PC line-in or microphone input. I have used it in Realflight, FMS, Aerofly, and it do have a good response... Try to download it..... http://www.sekiriki.jp/smartpropo/index.html Enjoy, Louie |
| Author: | Stanley [ Thu May 13, 2004 3:56 pm ] |
啊麥你唔知呢個 CRRCSIM 還可以玩 dynamic soaring,只要將風向 180 度倒轉,再把隻機開始時從高處插下就得,好過引架! |
| Author: | K.Y.Mak [ Thu May 13, 2004 7:46 pm ] |
Tsz Ming wrote: Mak
Very cool idea!!! But my question is...is it a freeware? Tsz Ming Tsz Ming, It is freeware. |
| Author: | Y C Lui [ Sun Jul 18, 2004 5:48 pm ] |
係阿麥屋企玩 F3F sim 好過癮﹐今日就試下係自己部 notebook PC 裝﹐唔掂﹗個畫面好慢﹐熄左 texture 勉強可以玩熱氣流版﹐但 F3F 版就點都唔得。 個法國網站話 " ... need a recent video board having a Geoforce 2 chip or more or equivalent ...", 我部 notebook PC 既 display adaptor 係 ATI RAGE MOBILITY-P AGP2X, 玩 FMS simulator OK﹐請問有無人知個問題係邊 ? |
| Author: | Guest [ Sun Jul 18, 2004 9:23 pm ] |
Notebook 既 display adaptor多數用主記憶(RAM), 試試改變(加大)display既記憶(RAM), 因為FMS用的資源較小. |
| Author: | K.Y.Mak [ Sun Jul 18, 2004 10:15 pm ] |
Y C Lui wrote: 我部 notebook PC 既 display adaptor 係 ATI RAGE MOBILITY-P AGP2X, 玩 FMS simulator OK﹐請問有無人知個問題係邊 ?
我部陳年notebook p-3 700Mhz + RAGE MOBILITY display,玩 FMS 完全冇問題,但係同一部机玩 F3F sim 就唔夠快。 另一台 P-4 1.4Mhz 既 notebook 就免強玩得到,不過都係冇部 P-4 1.8Mhz + Gforce2 咁流暢。 F3FSim 對 display card 既要求好高、所以D notebook 電腦都唔係咁得,反而、如果係 desktop 舊机、換張新 display card 就巳經 OK 啦! |
| Author: | ringo [ Fri Sep 24, 2004 11:14 pm ] |
I had made the sim cable Joystick to R/C.<br> I had test ok at: FMS, F3F, Ripmax, EasyFly, Acrofly Pro., and G2. New Version USB sim cable. I had test ok at: F3F 1.42, FMS, Ripmax, EasyFly and G2. |
| Author: | K.Y.Mak [ Sat Oct 02, 2004 9:04 pm ] |
ringo wrote: I had made the sim cable Joystick to R/C.<br>
I had test ok at: FMS, F3F, Ripmax, EasyFly, Acrofly Pro., and G2. Hello Ringo, What is the connecter type of the new sim cable? Is it for USB or Joystick port ? Does it work under Windows XP and 2000 ? A number of CRRCSIM users are interested in your new cable! |
| Author: | MingFai [ Sat Oct 02, 2004 11:40 pm ] |
I had test ok at: FMS, F3F, Ripmax, EasyFly, Acrofly Pro., and G2. Looking forward for sharing the cable connection information. |
| Author: | ringo [ Sun Oct 03, 2004 11:16 am ] |
1. Use joystick port (DB15-15pin). 2. I had test at Win XP and Win 98 - normally Win 98 to Win XP can use ok. Please call me. My phone no is 92228678. |
| Author: | MingFai [ Sun Oct 03, 2004 11:16 pm ] |
ringo wrote: 1. Use joystick port (DB15-15pin).
2. I had test at Win XP and Win 98 - normally Win 98 to Win XP can use ok. Please call me. My phone no is 92228678. Is that able to show us the detail???? |
| Author: | K.Y.Mak [ Tue Oct 05, 2004 12:02 am ] |
2. I had test at Win XP and Win 98 - normally Win 98 to Win XP can use ok. Please call me. My phone no is 92228678. Joystick port! Does it simulate a joystick ? If so, it should work with MS Flight Sim 2004 ? It's great for the desktop PC, but the notebook might not be able to use it for it don't have a joystick port. However, I have a USB to Joystick convertor, which came with my MS joystick. Do you think it will work with such converter ? I would like to try it out on my PC, when I come back from the holiday. See you soon! |
| Author: | ringo [ Tue Oct 05, 2004 12:37 am ] |
1. Yes, Joystick port. 2. it simulate a joystick. 3. It should work with MS Flight Sim 2004. 4. It's great for the desktop PC, 5. You can test with such converter. |
| Page 1 of 2 | All times are UTC + 8 hours |
