It is currently Wed Sep 23, 2026 3:33 am
PostPosted: Mon Oct 09, 2006 8:57 pm
Hi guys,
my friend is thinking of getting the DG 1000 from http://www.aero-fever.com. The shop is based in hongkong so im wondering if any of you guys has own one or seen one fly? how's the kit quality and flying characteristics like?
Thanks for your inputs.
PostPosted: Mon Oct 09, 2006 9:12 pm
Hi Mazon,
I have seen one still in the box last week. It is certainly a good-value-for-money model. It is a foam core balsa sheeted wing model. The fuse is fibre glass. The finishing is good and the construction seems very reliable, except may be the spar system. For a model of over 2m, I would say its spar (5mm carbon rod?) is a bit under spec. Anyway, I haven't seen one flying yet, so I can't tell you how it performs.
PostPosted: Mon Oct 09, 2006 10:42 pm
Thank you stanley, i will inform my friend. Anyone else have any information on it, kindly post here.
Thanks
PostPosted: Sun Nov 19, 2006 11:13 am
It is certainly a good flyer in the sky, lifting for the plane is good and easy to control. Loop, roll & inverted are just as good as those expensive plane. Several of my friends owns this plane and all their quality is good. A value for money!
However, if you are looking for a speedy plane that can sustain the pressure of deep dive and capable of making fast & sharp turns, this won't be the correct choice then.
Hope this could help!
