DC Voltage Booster
Feature:
1. It can realize single Lipo’s BEC supply electricity 5V for receiver by DC Voltage Booster,then make sure the
servo and receiver can work normally.
2. The range of input Voltage :3.7V-4.2V.
3. Operating current:Continued operating current:1A." The max operating current :1.5A."
4. It can rise the voltage often used in single Lipo’s BEC.
Using Specification
After be charged with electricity,put the plug of DC Voltage Booster into BEC . Attention: positive and negative must be according with the lable on the DC Voltage Booster.and then insert the JR plug into receiver.It can use normally . If you want to use two lipos , please take out the Voltage Booster , so as not to damage it.
