買遙控
http://rcsail.com/forum/viewtopic.php?f=3&t=128
Author:  kenlam [ Thu May 27, 2004 10:11 am ]
Post subject:  買遙控
我是初學者,想買套4ch-6ch遙控,有mix功能,有那牌子 / 形號 /價錢 . 介紹.
thank you
Author:  Willy (as guest) [ Thu May 27, 2004 10:58 am ]
通常初學者,開始時只會買套最平的 2 Channel 遙控,三百元有找。玩熟後才會買 6 至 9 Channel 電腦控。
其實頗少人用 6 Channel 控。你不如玩熟後,考慮升級、直接買套 Futaba 9 Channel 控好過啦。
Author:  Kevin YSL [ Thu May 27, 2004 11:09 am ]
買支三和$1100
Author:  Kevin YSL [ Thu May 27, 2004 11:17 am ]
當大家話你被騙的時候先買9仔啦!起碼玩得有引D! 6ch遙控,有mix功能 DG6000 三和 $1100
Author:  Guest [ Thu May 27, 2004 1:28 pm ]
Futaba 9 Channel is good choice
Author:  Guest [ Thu May 27, 2004 4:56 pm ]
幾多 ch 其實唔係好重要﹐因為大部份有 mixing 功能既控都已經有足夠既 ch 數目。揀遙控前﹐你先要睇下你想要也野 mixing 功能。一般滑翔機所需要既 mixing 有﹕
Elevator <-> Aileron mixing, 一般飛翼如 Bee都需要
Mixing 令左右 Aileron 可用獨立 servo﹐ 一般 aileron 機需要
V-tail mixing﹐V 尾機如 Shooting Star 需要
F3F, F3J 等賽機需要更多 mixing 如﹕
Flap -> elevator mixing
Flap -> aileron mixing
Aileron -> flap mixing
Aileron -> rudder mixing
Elevator -> flap mixing
Butterfly mixing
Author:  Guest [ Sat May 29, 2004 6:38 am ]
Only FF9 has "Butterfly mixing"
Author:  dannywong [ Sat May 29, 2004 11:24 am ]
I am a good example.
I started to play glider with a 4 ch Skyport. Then after half a year or so, I started to play glider with flaperons (2 servos on the wings), and I had to buy a Futaba 6TXA. Then, later, I started to play gliders with flaps and ailerons, so I had no choice but bought a 9C.
Now I play heli also, and the 9C is good enough. But I turn out to have 3 transmitters at home. What a waste of $$$
So, think thoroughly - will you play it long, and will you try others e.g. heli / power plane (I swore I would only play glider at the beginning, but after seeing heli, I played it, too)? If so, you better buy one good tx instead of several.
Author:  Guest [ Sat May 29, 2004 11:31 am ]
Danny is right. If your budget is limited, you may consider getting a 2nd hand JR / Futaba 9 ch transmitter. They typically cost about HK$1200 - HK$1500. The transmitter will serve you for quite many years to come.
Author:  Willy (as guest) [ Mon May 31, 2004 11:33 am ]
我 1995 年買的 FF8,都有 Butterfly (Crow) mixing 喎。是否 aileron 升高、flap 下降那種設定?
Author:  Kevin YSL [ Mon May 31, 2004 12:41 pm ]
千萬不要買二手控!!
Author:  billy (as guest) [ Wed Jun 02, 2004 5:42 pm ]
If i really only want to play different gliders, how about futaba 6TXA, is it enough to support all kind of gliders with mixer functions.
my choice is futaba skysport4 + FF9 (if necessery later)
or futaba 6TXA
have anyone give me some suggestions? thank a lot.
Author:  Stanley [ Wed Jun 02, 2004 5:58 pm ]
Hi Billy,
If you have decided that you are really interested in r/c modelling, go straight to purchase a FF9 - this will give you probably 10 years of trouble free operation without a need to change to a better control. I've, myself, gone through an incremental route with 2ch 27MHz, Skysport 4, FF7, FF8 and soon FF9. Now I have a few unused transmitters taking lots of places at home and are always the targets of my wife's throw out list! The only plus to have multiple transmitters is when you want to train new commers using a trainer cord.
Author:  billy (as guest) [ Wed Jun 02, 2004 7:14 pm ]
hi stanley,
thanks your comment, actually i'm afraid of taking a pro RC (FF9) with my 'green' skills, but anyway i am understand your experience.
