It is currently Fri Nov 06, 2026 11:44 pm
PostPosted: Tue Sep 13, 2005 2:35 pm
天文台預側大東風,為
PostPosted: Tue Sep 13, 2005 3:47 pm
I will GO ! :x Early in the morning ! Two packs of batteries ! Fly till the plane crash!!!
In fact I also want to go with Mak on this Saturday but I don't think I can get a day leave. This Saturday is the last chance for my practice :cry: :cry:
PostPosted: Wed Sep 14, 2005 7:58 pm
I also will go and see if anything can help.
Ah Kam
PostPosted: Sat Sep 17, 2005 12:02 am
Hi guys,
What time will you be up there tomorrow?
I am not sure what time I will be there, just hope to be there as earlier as 10:30am.
Cheers
PostPosted: Sat Sep 17, 2005 5:28 pm
今日馬鞍山
 Post subject: Handshaking in the air
PostPosted: Sun Sep 18, 2005 6:16 pm
So sorry for the air handstake (right arm vs right arm) with Stanley's Aris yesterday :?
咬一啖 Aris right wing was certainly painful : with the new wing joiner broken in air my plane's right wing panel pulled off from the sky. Unlikely to be repairable because :
- main spar was broken into 3 segments
- aileron was broken into 3 other segments
From this mid-air, seems top F3F ships like Aris are far much much stronger in structue !
Wish Stanley's Aris & Trinity can back to the air very soon !
With this 咬一啖 : Stanley's Aris must be able to run faster than the recent 36s F3F record :wink:
p.s. Thanks again to Eric for picking up the right wing panel "pieces" from the back side
PostPosted: Mon Sep 19, 2005 1:39 am
Sorry Wing, this is certainly one of the most spectacular midair I have ever seen! I think the relative airspeed between our planes must be over 200km/hr and I just don't know why the cut in your plane was so severer than mine. Interestingly, I didn't know there was a midair until I noticed there was a slight (really small) yaw moment of my plane and in just a flash of a second later I saw your plane's fuse spinning off in highspeed hundred of meters away! My goodness, I can't imagine the speed of your plane!
Don't give up! I think your plane is repairable. Ask the well-known master in sailplane repair - Y.C., you will be surprised that he can easily pull alive the dead plane from its grave!
