New Mini Bee
http://rcsail.com/forum/viewtopic.php?f=1&t=94
Author:  Tsz Ming [ Tue Apr 20, 2004 12:11 am ]
Post subject:  New Mini Bee
Please see this new molded EPP Mini Bee flying wing as follow.
Specifications:
Wingspan: 34.5 inch
Wing area: 1.68 sq.ft.
Airflow: RSB18
Weight: 10 oz
Wing loading: 5.59oz/sq.ft.
Battery:
a. 7.2 to 9.6V battery
b. 2 to 3 cells of Lipo
Motor :
a. speed 370 with 4 inch propeller
b. GWS IPS gearbox with 8 inch propeller
c. GWS EDP-50 type motor with 3.5 inch propeller
d. Mini Brushless motor
Radio: 3 channel with elevon mixing, 5 AMP ESC
Servo: Futaba #3107 type mini servo X 2
Author:  Tsz Ming [ Wed Apr 21, 2004 9:02 pm ]
Author:  Guest [ Tue May 11, 2004 7:52 am ]
35 inch Too Big.
Author:  GUEST [ Tue May 11, 2004 8:53 am ]
Yes, I think ~24 inch is better
Author:  Tsz Ming [ Mon May 17, 2004 8:10 pm ]
Post subject:  Mini Bee logo
Author:  Guest [ Tue May 18, 2004 1:27 pm ]
I am waiting for below 24 inch "MICRO BEE".
Author:  Kevin YSL [ Fri May 28, 2004 1:07 pm ]
幾錢先!??同有無motor?
Author:  Tsz Ming [ Fri May 28, 2004 1:32 pm ]
Kevin
Around HK$360 included speed 370 motor and two propellers (3.5 inch and 4 inch).
Author:  Stanley [ Sat May 29, 2004 12:52 am ]
360 蚊包埋摩打,真係好扺。如果我唔要隻 370 摩打,可唔可以計平D添呀,因為見啊邦隻自制無碳刷摩打後,我都想自已整番隻裝係mini電Bee上。
Author:  Tsz Ming [ Sat May 29, 2004 1:36 am ]
當然無問題啦,因個摩打有好多嘢攪,所以未掂。
如果唔要摩打的話,隨時call我交貨。
至於要減幾多錢囉...你話囉,或還是送你一打士啤槳作少少補償。
關於隻槳,有三吋半同四吋兩款任擇,暫時都試得幾好但還有一D改善空間。
子明
Author:  guest [ Tue Jun 01, 2004 4:48 pm ]
Post subject:  摺mini bee
請問隻 mini bee 有冇 spar? root & tip 幾多寸? 本身是否分開左右兩邊翼?
因為我想整隻摺得埋o既, 放得入背包, 用膠紙或磁石駁返埋。 玩完摺埋走人。
Author:  Tsz Ming [ Tue Jun 01, 2004 8:34 pm ]
Yes, the lenght of the carbon spar is 8 inch.
No, Mini Bee is one piece design by molding.
Yes, it is possible and sound interesting!
Author:  guest [ Wed Jun 02, 2004 3:14 pm ]
條 spar 係咪已經 mold o左去隻機入面?唔用得唔得ga?有條 spar 係度,隻機唔摺得,要分體式,我怕駁返埋強度唔夠 :? 。 你可唔可以幫我做o下 testing 哩? :D
Author:  Tsz Ming [ Wed Jun 02, 2004 5:51 pm ]
條 spar 係咪已經 mold o左去隻機入面?唔用得唔得ga?有條 spar 係度,隻機唔摺得,要分體式,我怕駁返埋強度唔夠 。 你可唔可以幫我做o下 testing 哩?
The spar is pre-molded inside the wing core but I think this is not a problem, because you can crop the wing to two pcs and join it back, just keep the spar inside the wing core by slide it in!
