It is currently Fri Jun 12, 2026 6:26 pm
PostPosted: Wed Sep 12, 2007 3:29 pm
本星期日下午在飛鵝山會有個定點降落賽,比賽規則和上次差不多。
比賽規則
1. 所有無動力之滑翔機均可參加。
2. 降落點將會在大會指定的斜坡面上。
3. 飛機降落停定後,機鼻與降落點之距離為計算距離。
4. 賽前大會會在斜坡上用噴粉筆畫上三個圓圈。直徑分別為 1米,3米及5米。
5. 距離在1米圈內得5分; 在1米及3米圈之間得3分; 在3米及5米圈之間得1分; 在5米圈外得0分。剛在分線上時,以較低分作算。
6. 若降落時撞到石壁, 即使飛機彈回圈內,亦只得0分。
7. 參賽者在開始降落時要先叫“Landing”。當叫"Landing"時,飛機機頭要指向外使飛機至少要繞一圈才能回到斜坡降落。若第一次降落不成功,可以繼續飛第二圈再降落,但得分會扣減一分。 即是說在第五圈才成功降落,即使距離在中心圓圈之內,亦只會得 5-4 = 1分。 每次降落之分數最低只會是零分,不會有負數。 得分會在降落後即時計算。
8. 基於公平及安全理由,參賽飛機之機頭不能安裝有硬零件。主審有權阻止他認為有問題之飛機出賽。
9. 比賽分五個回合進行,以五次得分之總和作為比賽成績。 最高25分,最低零分。
10. 飛機降落後,各機師無需立刻落山拾回飛機。待每個回合的所有飛機全部停定後,由降落點最遠的機師負責將所有飛機拾回。
PostPosted: Fri Sep 21, 2007 12:02 pm
Hi Ken,
Seems the spot landing contest was cancelled due to the wind was not sufficient on last Sunday. Are you going to re-organize at a later date?
Henry
PostPosted: Sat Sep 22, 2007 12:28 am
Hi Henry,
The spot landing contest did successfully held last Sunday although the wind was marginal. Ken has taken some photos, however, he is too busy this week to write up the report. I certainly hope the report will up soon. Cheers!
PostPosted: Sat Sep 22, 2007 11:19 pm
Henry
All of us have good fun of spot landing contest on last Sunday.
Wind is good too!
Two pilots had few round of playoff, the Winner is Eric finally.
Tsz Ming
PostPosted: Sun Sep 23, 2007 1:16 pm
Tsz Ming,
Usualy, the report will be posted after the contest. However, there was no report 2-3 days after the contest. That's why I thought the contest was being cancelled.
Even though I didn't participate the contest but I would like to know the result as well as seeing some photos.
If Ken is reading, please post the result and the photos as soon as possible.
Henry
