It is currently Sun Jun 14, 2026 8:20 pm
 Post subject: Easy EPP glider
PostPosted: Sat May 22, 2004 1:26 am
Some Easy movies:
http://www.sbslopers.org/movies/ellwood/windrider_easy.mov
http://www.sbslopers.org/movies/the_ruins/easy_dsing.mov
http://www.rcsail.com/easy_pattern.mov
http://www.rcsail.com/easy8.mov
http://www.rcsail.com/easy9.mov
http://www.rcsail.com/easy10.mov
http://www.windrider.com.hk/image/Launch_and_pick.AVI
http://www.windrider.com.hk/image/Looping_A.wmv
http://www.windrider.com.hk/image/Land_on_hand.wmv
PostPosted: Sat May 22, 2004 10:56 am
隻 EASY 幾時多左條炭骨架 ? 個日係清水灣飛隻無炭骨版發覺個 rudder 既效應幾好﹐估計係因為隻翼夠軟﹐導致飛起上黎有個較大既上反角。我鍾意隻機一俾 up 隻翼就會 V 起個形態﹐好似真滑翔機咁 ﹕
PostPosted: Sat May 22, 2004 11:17 pm
Hello Y.C
Yes, Easy already pre-molded a 12 inch carbon spar inside the wing root. The latest per-production sample was tested today. turning is good and the wing was not so flexible as you seen before.
Easy is now available in Waigo, it cost HK$400 only. Hope this plane could be more easier for novice to start RC slope soaring.
PostPosted: Sat May 22, 2004 11:24 pm
PostPosted: Sat May 22, 2004 11:29 pm
See all the parts listed as following picture:
Just plus in your RX, battery and servos, link the control rod to the horn, no need glue and screw. That is EASY!
PostPosted: Tue Jul 20, 2004 12:09 pm
I am a new player in this RC plane. How do i change the color for this plane? Should I use those color tapes? or others?
thanks.
PostPosted: Thu Jul 22, 2004 2:53 pm
我試過用五金鋪D噴油,不過land得唔好就好易刮甩D色。用熱力膠貼又比較煩,最方便都係用3吋color tape,不過Easy机身。太多圓位就比較有難度,或者可cut再幼d先貼會較易
Users browsing this forum: No registered users and 22 guests
